It also depends on when the dyno was calibrated. If ever. I had a car make the same horsepower on a Mustang dyno and a Dynojet. Two different areas of town. Two very different times of year. And naturally both operators said the others calibration was messed up.
Once again, dynos are tools. Numbers shouldn't be taken seriously.
Agreed. Everytime I ask about how they are calibrated, (what the actual procedure entails).... or how often they are calibrated, I get a blank stare.
Our local Dyno operator owns a chassis dyno, and tried to calibrate it so it reads the same as a dyno jet.
IF they were all calibrated correctly, you would always be seeing the same hp /tq results, SAE corrected.... from coast to coast, regardless of temp / pressure / humidity. If the engine /blower /ic /HE is one big heat soaked mess, then all bets are off, since the timing is pulled, and it drops like a rock. Even that can change depending on fuel used..and the tune. A 91 tune ( with 91 fuel) will pull timing well before the same 91 tune... but using 93 octane.
So its a useful tool, provided you use the same dyno each time.... and its calibration hasn't wandered off, or been re calibrated..between the times you use it. You may as well just roll race it, say in 3rd or 4th gear, starting at 20 mph, then time how long it takes to hit redline /rev limiter / 100 mph. Quoting max hp at one rpm, then max tq at another rpm is useful info.... but is really cherry picking imo. That's sales BS, esp when quoted at the crank. If it's a DD, what to look for is the entire graph, from idle to redline, or more specific, the area below the curve.
