007SHELBYGT
- Joined
- Sep 30, 2010
- Posts
- 37
- Reaction score
- 1
Ok so we are nearing spring here i have sht load of parts in boxes from last year and a forged long block with ported heads and cams 127550 comps for my 3 v shelby gt ...AS it sits it making a consistent 488 to the wheels on 10.5-11psi with a vortech v3 and 410s with a catless x and stock everything else ...its going in to the mustang shop tomorrow ..I was going to put my 8 rib 3.47 2psi more pulley set up on for better blower belt traction and a touch more power as the 6 rib is inconsistant ...while i was at it i have 60lb injectors and a gt 500 fuel system ...i was also going to put 3.55 gears back in as 4.10s suck for daily use and have no top end Next a new aluminum fly wheel and spec 2 clutch ...if it makes 520rwhp it will be like riding a grenade with the pin pulled ..but at least it will be ready for the new motor if duty calls for it ...IS THERE ANY CHANCE IT WILL LIVE THROUGH THE SUMMER WITH A GOOD TUNE A/F around 11.6 should i do it or leave it alone ..this will cost me 2200...to do the motor install now would cost 4k i dont have that yet so would i be stupid to pull the trigger on that set up ....
