HP pool...what will she make? Your guess is probably better than mine.
ulev1st
Mustang Addict!
Memphrica, Tn
Start..stock 2006 Stage2 Roush.
Added this winter:
COMPLETE rear suspension by CHE and BMR w double adj QA1's
4:10 FMS gears
Alum Driveshaft with loop
MGW shifter
Ram Dual disc clutch
BBK long tubes and x pipe with Roush mufflers.
BMR component subframes
BMR front K member with CHE brace
TEA CNC ported heads that flow 281I 207E at full lift of cams
Comp XE261H-16.5 Cams and springs
BBR cam VCT lock out plates cams set @114 deg lock
Whipple 2.3 wi GI Joe 8 rib kit and 3.00 blower pulley
ST Motorsports custom blower inlet (Adams finest work yet!)
ST Motorsports Custom CAI for same.
Mafia extender
Stock mass air
Black Diamond Wide oval Throttle body
Edge 60 psi injectors
Eagle/Diamond stroker kit 298 CU IN
MMR cryo oil pump and pickup
New ford cam tensioners and guides
Probe lower girdle
Mezeire elec water pump
Brisk plugs
CPR Fuel rails
ZEX wet kit
Canton catch can, rad exp tank, blower exp tank and PS reservoir
Twin GT 500 pumps
xp800
10,000 hp if you remember those extra hp stickers .......... i am gonna say to the ground around 640 to 650 with a real good tune . i cant wait for you to get it done , i am ready for a ride.
S197 GT
PINK Casting Director
Nor Cal
Depends on the shot of n2o....
I'd say with a 75 shot, you'll make 635rwhp.
TexStang
620 without the juice...me thinks... just depends on the tune
Slofoot
Memphis,TN
650 on a stretch with that blower. You'd better put the hairdryer on it if you want to be the KOTS in 08.
TexStang
I think he'll be in the 600's at least on blower, I don't see the whipple that much inefficient than the kb. Some KB people are in the mid 600's on 93...so i think lower 600s or more are attainable with the whipple
ZmanM3
The Evil One
Jackson, NJ
I figure I can guess what evert I want and if I'm actually right people are going to be really impressed, and if I'm wrong I'll be just like everyone else that didn't guess the right number.
94tbird
4R70W FTMFW
NY/NJ
id change out those brisk plugs if i were you haha
UrS4
Chicago
If Livernoise can get their 05 with a F1A procharger at 19psi to get 770 whp without nitrous and they have a stroker, heads, cams, and full exhaust, I don't see why you can't see lower 700's before the juice. Granted I don't know what psi the 3" pulley can produce so I could be severely overinflated with my guess. What size shot will you run?
UrS4
Chicago
Thanks,
I should probably read about centri's before I open mouth and insert foot.
So okay, how about 618 whp?
