Burke
Hey guys - couple of quick tech questions here:
1) regarding the bypass valve on the back passenger side of the blower - I have seen all the posts regarding raising and lowering the actual unit or running the stop bolt into the blower for quicker boost. Recently (since I do most of this stuff alone) I had my head in the engine bay with the car running and for the first time noticed that the small silver arm coming out of the bottom of the valve with the flat metal 'plate on it' (that sits on the bypass valve when the car is off) was retracted up into the valve - so essentially the plate was nowhere near the stop bolt and there is at least a pinkies width clearance between the bolt and the bottom of the arm when the car is running. Isn't that supposed to happen during actual driving? Is it supposed to be retracted like that at all times when the car is running? I recently dynoed it and boost levels were fine as the first time I dynoed - nothing seems different in driving - gas mileage seems the same. Input?
2) I recently swapped out my stock Saleen boost gauge in the dash for an Interceptor gauge. I got the 2 bar boost sensor mounted in the engine bay and everything wired up - no problems. My boost level is not showing correctly driving however - the gauge is calibrated correctly (slope adjustments, etc) and I have the proper negative at idle (According to Todd at Aeroforce) and he asked me if I was tapped into a positive boost vaccum - I spliced a T into the vaccum hose on the driver's side of the engine, a couple of inches forward of the JDM vaccum T set-up. Should I have this in a different spot?
Any help/advice is appreciated - thanks!
Dave
Dave
