5.0Shocker
Resident Bomb Tech
Thats sweetHere's mine. Details in an upcoming thread.
That's where I got my 90... one of the very few places these days that actually have a 3.5" to 4" 90 degree elbow in stock. The 4" 90 in your list above needs to be 3.5" on one side and 4" on the other, since the Vortech inlet is 3.5".There is a company called www.siliconeintakes.com that sells silicone hose and joiners. All you need to make an intake is 1- 4inch 90, 1-4 inch 45, 1- 4 inch joiner, and 4 T clamps. Price is around 60 dollars. You will need to convert to blow though mass air. and convert to vent to atmosphere blow off. Tune needed to get the most out of the change.
By the way, I'm using mine without the shield. The 90 keeps the pipe in place nicely, so it doesn't hit anything. The only down side is that it rubs against the radiator cover, so I encourage you guys to consider that when making your measurements.
It's a painted cover, so I don't really want to do that. I will probably have to, though, since I can't take anything off the 90. Yet another thing on my to-do list.Can't you trim the radiator cover or does it still rub with trimming?
Got it...I need a draw through setup...sigh....
Built short block, 9.0 CR. Stock heads, for now. That's my next project, after this one. This one is the perfect lead-in to a P&P job, IMHO.Oh I gotcha! You have a built motor right?
You have a draw through, you need a blow through setup for this kind of setup.
Cool thread! My Paxton 2200 has a 4" inlet compared to the 3.5 of the vortech/1200... right? As of right now I can't make any more power than I already have. But when I build a motor I'm sure I will have some form of power pipe with a blow thru setup to go in. Setups look great fellas.
Greg, I assume this is where you already got the "mod bug" for a power pipe.
Wonder if I could just get the Power pipe and use my stock MAF/housing?
AFM makes their product with MAFs built in. Getcha one of those if you really want to do this.Wonder if I could just get the Power pipe and use my stock MAF/housing?
You can, but since it will still be draw thru you need to make connections in the power pipe to attach the hoses for the bov
