Interference fit on steering knuckle bolts?
Enfield
Shenandoah Valley
In the midst of a suspension refresh for the '07 GT. When attaching new Koni STR.T front struts to the steering knuckle, I find that the oem Ford bolts won't slide right in the appropriate hole in the strut. In a way this makes sense: you don't want any slop in that connection that might affect steering dynamics. Should I just force the bolt through with an impact wrench when assembling?
FWIW, the car is getting new GT500 control arms and strut mounts, to go along with Bullitt springs. OEM sways at this point, with new endlinks and MOOG tie rod ends. Full rear refresh, too.
TIA, Enfield
DieHarder
Post a pic. Sure they sent you the right ones? You should Not have to use an impact wrench on those bolts. Call the company you bought them from and describe the issue/check the model numbers.
Enfield
Shenandoah Valley
Accidentally posted this on the 4.0 forum...
The Koni part # is 8750-1030. Diameter of the mounting bolt is ~14mm; its threads go into the mounting hole, but the unthreaded portion does not. Have gotten in touch with Tire Rack, the supplier. Beginning to think that the mounting bolt is not the correct one.
Enfield
Shenandoah Valley
Bolt fits snugly into the 14mm gauge hole, but not into the strut. I could probably drive it through with a light rubber mallet. Too thick a coat of paint?
[jpg didn't load]
MrBhp
If a light rubber mallet will get it thru, you are good to go. Probably just the coating. Give it a few taps. If it starts to go in, I personally would give them a spin with my battery operated impact set to low. I've done this many times. It doesn't damage the bolt or the strut. Unless you really do have the wrong bolt. Are you replacing the bolts? I think I've been instructed by all the instructions I've read on struts to replace the bolts.
Enfield
Shenandoah Valley
Will wait to check camber after finishing the job before ordering new bolts. On the side I've already changed over, the half-moon at the top of the original mount was facing in, and camber was -.9 degree. This is with Bullitt 5510 FA springs.
