GT500 specs:
http://iihs.net/fsm/?dir=168&viewfile=SPECIFICATIONS.pdf
5.0 4v:
http://iihs.net/fsm/?dir=822&viewfile=SPECIFICATIONS.pdf
2011 GT500:
http://iihs.net/fsm/?dir=831&viewfile=SPECIFICATIONS.pdf
4.6 3v:
http://iihs.net/fsm/?dir=158&viewfile=SPECIFICATIONS.pdf
These specs are important for comparison purposes. Why? Because all of these motors hold quite a lot of power in stock form. The thing that always goes first is the rods. You never hear of a spun bearing unless someone put delo in the motor or something along that line of stupidity.
To me it means that Ford factory specs, machining, and parts are very good. It also means that the average person can use Ford specs with stronger components and be just fine with more power. An all out race motor would be different.
All too often people live in the past and don't even bother to think of why clearances are tighter, motors make more power, and they live longer than they ever have. It's because the machining is more precise, better oil is available, and manufacturers know more about internal combustion motors and the theory behind them than they used to. It keeps getting better.
I figure that if a supercharged 5.4 4v with a warranty has a bearing clearance of .0009-.0019" then those are good numbers for my motor. Likewise with the rest of the specs. The only exception is 2618 pistons which need extra clearance to account for metal expansion.
There are lots of theories on motor specs. Why not use the specs with a great track record?
