- Joined
- Dec 22, 2010
- Posts
- 25
- Reaction score
- 0
Jpc would like to announce that we have test results on our CNC cylinder heads for the 2011 5.0L. We have just completed the install/testing on the heads for MM&FF and have a sneak peek of the results. We are not at liberty to post up complete dyno sheets at this time but we can let you in on some of the gains we experienced. The car we used for testing was Joe Marini's 2011 6spd manual GT. The car was equipped with a set of Kooks longtubes, 3" Off-road X-pipe, Bassani mufflers, JLT CAI, and a custom Diablosport/JPC tune. The car baselined at 424rwhp, we installed the cyl heads within 24hrs and did not change anything but the cyl heads, we made sure all of our temperatures were consistent and this is what we found:
A 36rwhp gain at 7,400rpm, 21rwhp gain at peak hp which was 6400rpm, 18rwhp gain at 5,000rpm, 5rwhp gain at 4,000rpm. The heads feature RGR designed cnc porting and a 5angle valve job. They are equipped with stock valves and we shim the valve springs, for added valvetrain stability at high rpms. We will offer a cnc program that also includes camshaft area modifications/clearancing for larger camshaft profiles. This is a must for any camshafts over .500lift. We are currently accepting cores for porting and have an apprx 7 business day turn around time. Please contact us if you have any questions. Thanks JB@JPC
