Helmholtz resonance chamber, it utilizes the same effect that you get when you blow across the opening of a bottle.
It can be used to boost power at specific RPM ranges, and it can also be used to reduce noise. I suspect in this case its reducing noise, but its hard to say for sure.
There are some vehicles that will see pretty dramatic losses when these chambers are removed.
