LuckyH
That's good news...better late than never...well...at least in theory!
That's what the girlfriend tells sometimes
Glad to hear it finally arrived and from what it sounds the results were worth the wait!
What's next?
Good plan; do you have any intentions of ever going FI? I did the NA route and it was fun for a while but in the end I should have found a power adder and avoided the cost of NA parts...although with the parts you have listed they will work either FI or NA.
I did all the bolt ons save heads and doing research on them they were not worth the cost; 10-15 hp vs the cost of heads and a headswap made the decision to not do the heads and go the FI route easy. There is some satisfaction in being NA but in the end it is not cost effective.
I got a ridiculous price on my blower when there were 2-3 for sale which made it easy to pull the trigger.
I had Hot Rod cams and picked up 33 hp/3 ft lbs tq when I had the LT's and catted H pipe installed..my numbers are lower being an automatic...you will have to read and decide if you want power or sound for cams and whether or not you go the NSR or SPR route..NSR's are easier/cheaper since you can swap the cams yourself, if you go springs required then it gets harder to install and more expensive.
