mustangtcs
I have had these issues ever since I put the kenne bell on my car. Here is my setup. 2005 Mustang GT auto 32,000 miles. 4.10 gears. Kenne bell 2.6 stage 1. SCT BA2600 maf. Siemens deka 60lb injectors. brisk 3vr16s plugs. Kenne bell BAP wired on at all times. 3 3/4" pulley. Tuned by Jon Lund in person at evolution performance. My problem has been there ever since I installed the supercharger and using Jon's startup tune and is still there today after final dyno tune. When I first start the car it idles great at 14.5 afr. When I tap the pedal nothing happens. I could put it to the floor real quick and get no response. When I try to drive its difficult because I have to hold the pedal down for a bit before it moves. The Air/fuel will even dip lean for a split second during this hesitation period. Now if I try to get on it at all and I have to in order to get the response its sputters above 3000 rpms but the afr is at 10.1 or so. But once the car is warm it drives great and pulls to redline hard. also around 11.4 afr. The hesitation is less but still there. Also my mpg's are around 8 miles per gallon. This has been since the beginning of last winter. While at the dyno the car was hot because I had drive it an hr there for the tune so Jon didn't get to experience this. I have datalogged a lot and lund racing says the logs look good. I originally had autolite ht0's and just switched the plugs to brisk today and no change. I am close to just taking my car to Evolution and dropping it off and just letting them figure it out but if anyone could help it would be great.
UPDATES WILL FOLLOW WHENEVER POSSIBLE
