Koni Strut groan and rattle
302GT
Charlotte, NC
I had a Koni str.t strut do the same thing (groaning noise). Then after a while it got clunky. Even one of my rear Koni str.t's took a dump in about a year. I was on SR springs (1.5" drop). The car bottomed out in the rear a lot which I'm sure led to the failure.
FYI, I was using the 11+ struts w/OE mounts. Car is currently on OE shocks/springs and doesn't make any noise at all. It's quite nice actually.
For a short time I did have Bilsteins for the rear after the Koni died. The difference between Bilstein and Koni Strt.t isn't even comparable. Much more control with the Bilstein. Only problem with Bilstein (even with OE springs) was the "choppy" ride at times. The interstate I frequent is concrete and has some undulations in the surface. It'll make you nauseous.
Jinx
Photography Blogger
Mebane, NC
This is just me compressing and letting go with my hand.
I put the BMR spring and Steeda HD mount on the stock strut. The sound appears to have been eliminated. I was toying with the idea of brembo brake chatter; but I guess the KONI POStr.t is the problem. I hear a faint clunking; but I think it's just the other KONI strut beginning to do it; gonna do that one next when I have time. Pain doing this alone. Lol.
5tangiac.0
Houston, TX
I have had the frpp non adjustable shocks on p springs with 05-09 gt500 mounts for a few thousand miles now. No issues yet. Knock on wood....
Jinx
Photography Blogger
Mebane, NC
End endlink werent the problem. Sway bar was removed completely during this time. It was fixed two months ago by replacing the Konis with a different strut.
