petersonb
Okay, so this has been an ongoing issue for about 2 months now.
All online research has shown many people with similar symptoms, but I have yet to find anyone with the exact symptoms. Thus, I turn to the great people of s197forum
ISSUE SUMMARY AT THE BOTTOM, if you don't want to endure the long read.
The problem first presented itself while driving up a hill:
1. no feel in the throttle
2. No power
3. Rpm dropping, regardless of throttle action
At this time, my fuel pressure gauge wasn't connected. I was on the side of the highway, I pulled CEL codes, said fuel pressure at the rail. I went under the hood and pulled the regulator body from the rail and noted air in the line. Put it back on and turned the car over. It took a while to refill the lines, but then the car started and I babied it home 25mi through the mountains.
I ordered a new fuel pump (replacing the already-installed Aeromotive Stealth 340lph). It took a few days to arrive. Once it arrived, I took the car for another test spin, did a few WOT pulls.... And NO problems. I had reconnected my fuel pressure gauge, and saw ~50-52psi, like normal.
I sent the fuel pump back and drove the car fine for 2 weeks or so.
The same problem occurs again, so I order another fuel pump. The car drives fine for a week or so, but I keep the Pump in the trunk just in case.
I have made two 1200mi trips in the mustang in the last week and a half. The first one, the problem occurred about 30mi in under hard acceleration. I pulled over and replaced the fuel pump. Pulled onto the highway, gave her some throttle, and sure enough: fuel pressure STILL dropping to about 20psi (from 50ish). I continue my (necessary) trip, making 4 more stops total.
Each time, the pressure drops more and more until its at zero, the car stalls, and I'm on the side of the road. I pop the hood, remove the regulator, let all the pressure/fuel out of the lines, reconnect, and keep driving.
I return from the first trip, replace the pressure regulator, problem seems to go away. Car runs fine for a day or so, then I make a ~200 mi trip and the problem is present again. Acceleration, fuel pressure drop.
I pull the fuel filter, everything is in check there. I disconnect (what I think is) the hose for PCV (from valve cover to intake, just before throttle body). Checked via carb cleaner for vacuum leaks -- nothing noticeable.
I put everything together, and hot rod around town for the night. Hot rods just fine around town.
Problem occurs again the next day. I have a Kenne Bell Boost A Pump. There are two wires that go to a dial which either increases or decreases the fuel "boosting." If there is no dial present, one should simply connect these two wires together....in effect, this is the same as the dial being set to "full ON"
I try driving with the wires completely connected, and completely disconnected.
Issue is present under both conditions, but seems less severe with them disconnected (meaning dial would be full OFF -- I.e. no "boosting")
Second 1200mi trip. I make it about 300mi without issue. Then, same exact problem; same exact repair. This time I completely disconnect the boost a pump. This time I reset the trip meter to see how far I can go without incident. (Sneak peek: 640mi)
Car drives fine for the rest of the 300mi to destination (Nashville, TN). Doesn't drive perfect, but drives as expected. Without the boost a pump, I expected it would be fine until there was a large fuel demand, then would run lean. I kind of test it on the highway and exactly as expected.
I drive 600+ miles like this. Reliable, but not high performance, as I expected.
Thinking I had found the problem (the boost a pump), I drive home happy, thinking I've solved the problem after months of ripping out my hair.
Fast forward 300mi. Driving on flat ground, cruising at 80mph, loss of power, fuel pressure *slowly* decreases until it gets below 10psi and engine sputters to a stop.
The usual repair (remove pressure regulator, replace, turn over motor, drive) gets me going for the remaining 300mi home.
I haven't driven the car since, until today (trip was last week). Drove to the mechanic shop (where I am now) with no noticeable issues. Then again, it's just low speed city driving.
SUMMARY:
Loss of fuel pressure under acceleration (usually) and normal driving (occasionally). Started with incidents few and far between, now consistently messing up.
I've replaced fuel pump, pressure regulator on the rail, checked for vacuum leaks, checked fuel filter, disconnected the aftermarket Boost A Pump.
The remedy so far has been opening the fuel lines (by way of removing the pressure regulator from the rail), then reconnecting. This remedy has been successful for about 100-300 highway miles at a time.
ABOUT THE CAR:
2006 Mustang GT
Stock motor/internals (4.6L)
GT500 52lb injectors
91 octane fuel
M112 Supercharger at 12psi
Aeromotive Stealth 340lph fuel pump
Autometer A/F ratio gauge
Autometer Fuel Pressure gauge at rail
465hp/455tq at wheels with tune from Racers Edge Tuning in CA
Thanks for reading, and THANK YOU in advance for any help that fixes this issue. It's been a miserable journey.
2. No power
SUMMARY:
ABOUT THE CAR:
2006 Mustang GT
91 octane fuel
