In my experience 02 sensors are seldom the cause of an o2 sensor related code. If you are near Gainesville i have a stock 06 throttle body you could test. Only has 10k miles on it.Well the gasket didn’t fix it so maybe it’s the throttle body since it got codes I forgot to take it apart and look at the gears, but under load at higher rpm the car will do wrench in dash mode, also 02 sensors are definitely bad cause there codes are there and part of the exhaust needs to be reattached so maybe that’ll cure it.
Yep you solved it. A more appropriate response is, thank you everyone for helping me diagnose my issue.When you manually moved the throttle blade you probably damaged the tb motor. You need to pull it apart and check the internals. Probably stripped a gear.
