Major 2010 Mustang Info!
LAK3RS
Original Member
DFW, TX
http://forums.bradbarnett.net/showthread.php?t=474691
2010 Mustang Gt with Performance Pack Option Sheet
APPEARANCE PACKAGES YPJAA LESS APPEARANCE PACK YPJ01
AUDIO - RADIO FREQUENCY IBMAB NAAO RADIO FREQUENCY
AUDIO - RADIOS IBAFC CDX6+ RAD W/ SP SENS VOL CONTR IBA00 ALL RADIOS IBA02 ALL NON CASSETTE RADIOS IBA03 ALL STEREO RADIOS IBA05 ALL RADIOS WITH CD PLAYER
AUDIO - SOUND SYSTEM IDAAH SUBWOOFER/AMP. SOUND SYSTEM
AUDIO - TYPE OF AUDIO BROADCAST IBYAD SATELLITE DIGITAL BROADCAST
AXLE - FINAL DRIVE RATIO - SINGLE SPEED EGAJB 3.73 FINAL DRIVE RATIO
AXLE DIFFERENTIAL - REAR EGJAC LIMITED SLIP REAR AXLE
BODY STYLE BS BJ 2 DOOR COUPE-4 LITE
BRAKES - ANTI-LOCK ABS/TRACTION CONTROL YCXAA LESS MRKT CB-ABS/TRAC CONT YCX01
BRAKES - PARKING BRAKE GRIP FAFAB LEATHER HANDBRAKE GRIP
CAMERA J3KAA LESS CAMERA
CLIMATE - AIR CONDITIONING AC B MANUAL AIR CONDITIONER AC 1 ALL AIR CONDITIONING
CONVENIENCE GROUP AAMAM FRONT COMFORT PACKAGE C2
DECKLID PANEL - FIA FHTAA LESS DECKLID PANEL - FIA
DOOR SILL PROTECTION - FRONT A1PBA FRONT SCUFF PLATES-ILLUMINATED
DRIVE DR B 2 WHL L/H REAR DRIVE DR T ALL 2 WHEEL LEFT HAND DRIVE DR 1 ALL LEFT HAND DRIVE DR 2 ALL 2 WHEEL DRIVE DR 6 ALL REAR WHEEL DRIVE
ELECTRONIC PACKAGE HKLAD MEDIA GATEWAY PACKAGE
ELECTRONICS PACKAGE YQHAA LESS ELECTRONICS PACKAGE-MKTG
ENGINE EN HZ MOD 4.6L 3V OHC VCT NA ALV8 EN 0G ALL GAS/GASEOUS ENGINES EN 0M ALL MOD 4.6L GAS ENGINES EN 08 ALL 8 CYLINDER GAS ENGINES
ENGINE - EMISSION REQUIREMENTS DGAAB 49 STATE/NON GREEN STATE REQ.
ENGINE - HEATER DEBAA LESS IMMERSION HEATER
ENGINE AIR DEFLECTOR DAZAB ENGINE AIR DEFLECTOR
ENGINE COVER - UNDER HOOD C7SAA LESS ENGINE COVER - UNDER HOOD
EXHAUST TIPS F2EAB ROLLED EXHAUST TIPS
EXTERIOR ACCESSORIES PACKAGE YQ9AA LESS EXTER ACCESSORIES PACKAGE
EXTERIOR APPEARANCE GROUP AB2AA LESS APPEARANCE GROUP
EXTERIOR OPTION PACKAGE YQ8AA LESS EXTERIOR OPTION PACKAGE
EXTERIOR PAINT - ACCENT STRIPE - BODYSID CJPAA LESS ACCT STRIPE-BDYSD COLOR CJRAA LESS BODYSIDE ACCENT STRIPE
EXTERIOR PAINT - ACCENT STRIPE - HOOD CJTAA LESS HOOD ACCENT STRIPE
EXTERIOR PAINT - 2003/04/05/06 EXTERIOR PN3KD STERLING GRAY METALLIC
EXTERIOR TAPE STRIPES-FIA FIWAA LESS TAPE STRIPES-FIA FLEET YZKAC COMPANY CAR
FOOT PEDAL DESIGN GCEAE FOOTPEDALS-UNIQUE METALLIC FIN
FUEL - ASSEMBLY PLANT FUEL FILL FF1AB NORMAL FUEL FILL
FUEL ENGINE FUEL CAPABILITY GBVAF UNLEADED FUEL CAPABILITY GBV01 ALL NON FLEX FUEL CAPABILITY GBV02 ALL GASOLINE FUEL CAPABILITY
FULL VEHICLE COVER-FIA FIPAA LESS FULL VEHICLE COVER-FIA
GVWS AAZCE 4620 LB. GVW
HOOD SCOOP-FIA FHQAA LESS HOOD SCOOP-FIA
I/P INSERT BBQAF I/P INSERT-METALLIC FINISH
INSTRUMENTATION - CLUSTERS HCFAQ INSTRUM CLUSTER-6 GAUGE
INSTRUMENTATION - MESSAGE CENTER HKDAB MESSAGE CENTER
INSTRUMENTATION - SPEEDOMETERS HDHAB MPH/KPH SPEEDOMETER
INTERIOR DECOR LEVEL BBBAC INTERIOR DECOR-LEVEL A
INTERIOR FLOOR MATS - FRONT BBHAB FRONT THROW IN CARPET FLR MATS
INTERIOR PACKAGES A2TAA LESS INTERIOR PACK
INTERIOR TRIM COLORS - ALL 000DW CHARCOAL BLACK
LABELS - SPECIAL LANGUAGE AEAAE ENGLISH LANGUAGE LABEL
LAMPS - FRONT FOG JBKAB FRONT FOG LAMPS
LAMPS - HEADER LIGHTS - ROOF JCGAF HEADER DOME LIGHT W/O MAP
LAMPS - HEADLAMP CONTROL JEDAC AUTOMATIC HEADLAMP CONTROL
LAMPS - HEADLAMPS - DESIGN JBBAB HALOGEN HEADLAMPS
LAMPS - HEADLAMPS - RUNNING JBCAA LESS DAYTIME RUNNING LAMPS
LAMPS - LIGHTING PACKAGES JBWAC LIGHTING PACKAGE LEVEL A
LICENSE PLATE BRACKET - FRONT CLVAA LESS FRONT LICENSE PLATE BRKT
MARKET DERIVATIVE MD F FORD DIVISION DERIVATIVE MD 1 FORD & MERCURY MRKT DERIVATIVE
MEDIA GATEWAY MODULE (MGM) IEVAB SYNC (MEDIA GATEWAY MODULE)
MIRROR - EXTERIOR DRIVER BSDBQ DRIVER C/K POWER MIRROR
MIRROR - EXTERIOR PASSENGER BSFBQ PASS C/K POWER MIRROR
MIRROR - INTERIOR REAR VIEW BSBAR ELECTROCH MIR W/ CMPS AND MIC
MK CB-DRV SEAT/HD REST/LUMBAR YK1AB 6 WY PWR DRV ST/PWR LUMBAR YK101
MODULE CONFIGURATION TDAAW OVERSPEED WARNING DISABLED TDABR REMOTE ENTRY W/KEY IN ENABLED TDAD9 DRL DISABLED TDAHQ TRANSMISSION - MANUAL TDAM9 BRAKES-W/O ABS/TC/VD/RSC/IVD TDANG DOOR AJAR TELLTALE-DISABLED TDANH SHIFT INDICATOR LIGHT-ENABLED TDANK SPEEDOMETER CALIBRATION-N.A. TDAN4 TPMS ENABLED
MRKTG REGIONAL PKGS 1 YLAAA LESS MRKTG REGIONAL PKGS 1
OWNER HAND BOOK PACK AEDAB OWNER HAND BOOK PACK
PLANT BUILD REQUIREMENTS AAGCL FLATROCK ASSEMBLY PLANT - USA
PROGRAM CONTROL AD6HA 2010 JOB #1 PROGRAM CONTROL
REMOTE STARTER-FIA FIVAA LESS REMOTE STARTER-FIA
RESTRAINT DEVICE PACKAGES CN7AE BLT W/D&P FRNT/1ST ROW RSTRNT
ROOF - ALL ROOF COLORS R99Z9 NON/COLOR (ROOF)
ROOF - CONVERTIBLE BOOT - ROOF COVER CHRAA LESS CONVERTIBLE BOOT-RF CVR
ROOF - LESS CONVERTIBLE ROOF RZZZ9 RZZ00 LESS CONVERTIBLE ROOF
ROOF - OPENING PANELS CHAAA LESS ROOF OPENING PANELS
SAFETY PACKAGES YPBAB SAFETY/SECURE PACKAGE
SEAT - FRONT SEAT TYPE FS A SEAT-SPORT-DRV/PASS
SEAT - TEMP CONTROLLED DRIVER BY1AB DRIVER HEATED SEAT
SEAT - TEMP CONTROLLED PASSENGER BY2AB HEATED PASSENGER SEAT
SEAT ADJUSTER - DRIVER BYPAC POWER 6-WAY DRIVER SEAT ADJUST
SEAT ADJUSTER - PASSENGER BYQAC POWER 6-WAY PASS SEAT ADJUST
SEAT LUMBAR SUPT - DRIVER SEAT BWRAC LUMBAR SEAT SUPT-DRIVER PWR
SEATS - MRKT CB-TEMP CONTR ST-DRV/PASS YCLAB MRKT COMB-HEATED SEAT-DRV/PASS
SECURITY SYSTEMS HNAAJ PERIM ALRM W/ INTRU&INCL SNSR
SIDE SCOOP - FIA FHSAA LESS SIDE SCOOP - FIA
SIDE STRIPE - FIA FHUAA LESS SIDE STRIPE - FIA
SMOKERS PACKAGE J3CAA LESS SMOKERS PACKAGE
SPECIAL BUILD REQUIREMENT AADAA LESS SPECIAL BUILD REQUIREMENT
SPECIAL BUILD REQUIREMENTS SBRAA LESS SPECIAL BUILD REQUIREMENT
SPEED AUDIBLE WARNING DEVICE HLIAA LS SPD AUDIBLE WARNING DEVICE
SPLASH GUARDS - REAR A1KAA LESS REAR SPLASH GUARDS
SPOILER - FIA FIIAA LESS SPOILER - FIA
SPOILER - REAR BPFAA LESS REAR SPOILER
SPRING - COIL LEFT FRONT TAAQ4 AR33 5310 F* L/F COIL
SPRING - COIL LEFT REAR TAEKW AR33-5560-D* L/R COIL
SPRING - COIL RIGHT FRONT TACQ4 AR33 5310 F* R/F COIL
SPRING - COIL RIGHT REAR TAGKW AR33 5560 D* R/R COIL
STAR RATING PERF LEVEL A5MAB STAR RATING PERF LEVEL 1
STEERING WHEEL GTACJ ST WHL-LEA WR WITH REDUND CONT
SUSPENSION - PERFORMANCE PACKAGE DWBAB PERFORMANCE PACKAGE
SUSPENSION - STABILIZER BAR - FRONT DYKAC UPSIZED FRONT STABLIZER BAR
SUSPENSION - STABILIZER BAR - REAR DZLAB REAR STABLIZER BAR
TAPE STRIPE PACKAGE YRCAA LESS TAPE STRIPE PACKAGE
TERRITORIES - GENERIC COUNTRY GROUPINGS SATAB GENERIC COUNTRY GROUP 1
TERRITORIES - NORTH AMERICA PRINCIPLE WANAB USA WAN01 ALL U.S.A. AND CANADA WAN02 USA,USA TERR,CAN,MEX WAN03 ALL USA AND MEXICO
TIRE INFLATION KIT HJBAA LESS TIRE INFLATION KIT TIRE SPARE D3MCJ SPARE TIRE-T185/60R17
TIRES - 19 INCH CAR/LT TRK D3IBU P245/45 R19 98W RATING
TPO/ORDER CODES 0-300 YZBAA LESS TPO/ORDER CODE YZB01
TPO/ORDER CODES 301-599 YZCBA TPO/ORDER CODE 400A
TPO/ORDER CODES 600-999 YZDAA YZD01
TRANSMISSION TR SK 5 SPD MAN TRANS TR3650 TR 0M ALL MANUAL TRANSMISSIONS TR 05 ALL 5 SPD MANUAL TRANSMISSIONS
VERSION VS AX GT VERSION - CAR VS 0S ALL EXCEPT SHO VERSION
VERSION PACKAGES AACAA LESS VERSION PACKAGES
WHEEL - HUB COVERS D5DB2 CTR HUB ORN-PONY LOGO/SPINNER
WHEEL - LOCKING LUG NUT KIT D5HAB LOCKING LUG NUT KIT-WHEEL
WHEEL - SPARE D17B3 SPARE WHEEL-17X5 MINI STEEL
WHEEL SIZE/STYLE - 19 INCH D2VAX 8.5 X 19 MACHINED ALUM WHL
WHEELBASE A2WAQ 107.1 CAR WHEELBASE
WINDOW LOUVERS - FIA FHRAA LESS WINDOW LOUVERS - FIA
WINDOWS - REAR SIDE B2DAF FIXED REAR SIDE WINDOW
ZF-A-L-TRND MNI PRF OV MLD PBL 2Z4DW 2Z400 ZF-A-L-TRND MNI PRF OV MLD PBL
TOP
LAK3RS
Original Member
DFW, TX
O yeah, and the best part is the weight....who ever reads it is going to shit themselves immediately...I promise!
Hawgman
THE fucking bad guy
Texas
I must be missing what the "major info" is...
BTW, moving to the Mustang Chit Chat forum
LAK3RS
Original Member
DFW, TX
Damn Doc...your breaking my balls man...breaking my balls!
Check out the weight of the car, as well as the engine, tranny, and other things as well.
LAK3RS
Original Member
DFW, TX
It doesn't say GVWR, is says GVWS....
BTW, Roper, I'm watching the LAKERS game!!! You should be doing the same!
dude come on now.... use your brain, NFW Ford's building a 4600lb stang! 1000 lbs more then the current model!
Hawgman
THE fucking bad guy
Texas
Like I said.. I am missing the "major info!". It has a 4.6L V8, 5 speed 3650, and weighs around the same. Other than it stirring everyone up over the body changes and interior changes, and a new color (or possibly a renamed color again) I am missing what is so "major" about it.
Dex
I'm Dexolishous
Utah
The steering wheel sucks your balls.
