Mcleod 1400 adjustable throw out 2011+
popeye
Does anyone have any experience with these on the MT82?
Department Of Boost
Alpha Geek
Do you mean slave cylinder? If so they're a waste of money. The stock stuff when shimmed correctly have proven to work flawlessly under the most extreme of situations.
o2sys
NY/NJ
What's adjustable about it? Pedal feel or travel?
popeye
The actual assembly is adjustable. You have to know all your dimensions as you put everything back together. Then you screw in or out to get just the right clearance. There are a bunch of you tube how to vids.
