McLeod RST too much clutch for 450whp? What do you guys use?
RedMosesSC
NYC
I need to get my clutch/Flywheel done before the 2nd annual S197 track day at Atco, i was doing my research and it seems like everyone has had horror stories with everthing but the McLeod stuff. They are Def pricey but since a clutch swap is a big job id rather pay a premium and do it only once. Also plan on getting an OEM slave and Pilot Bearing.
I was checking stock at American Muscle and the sales guy seems to think that its too much clutch for my application, im only putting down about 450whp and i dont have any plans to break the 600WTQ plane anytime soon... (see sig for Mods)
Any one have recomendations for my application? The car sees about 8k miles a year, mostly street with a hand full of AutoX/Road coarse a year and a couple of Drag events a year. My slowly dying stocker seems to be holding up for street and AutoX although its hard to swtich gears here and there but it really does NOT like Drag racing. Id like to keep a stockish pedal feel.
Although im not looking forward to shelling out the wad for the McLeod, it seems like its the way to go, do they have a model for S197's making less than 6-800hp? Whats a good alternative? heard to many bad stories about Spec...
Thanks in advance for your opinions
weather man
Persistance Is A Bitch
MN
SPEC 3+... barely any more pedal pressure and modulates well.
Fantas
I haven't personally owned and used the RST; however, I have an RXT and have had absolutely nothing but good things to say about it so far.
doogie
SE WI
I went through the same dilemma last fall and ended up going with the Exedy Mach 500... which I now regret as the pedal pressure is a bit stiff. If I had to do it over again, I would just have spent the extra money for the RST.
better to have too much clutch than too little....
I had a Spec 3+ in my 06 Vert - worked very well, based on HP/TQ specs, it was too much clutch....
Hatchman
Stangless
Chesapeake, VA
I have a Spec 3+ and AL flywheel, and it's too much clutch. Very on/off, no slip. When it gets hot, it gets worse. I didn't think it had much more pedal pressure until I did a "side by side" comparison with a couple of stock clutches, and this Spec 3+ does have a lot more pedal pressure.
The good news is, it doesn't slip, and still works like the day I bolted it on 6 years ago. Next will be a McLeod and going back to a steel flywheel.
If you want the best street driving clutch you will ever have go rst. If you want to stay single to save money and have a little more pedal effort go exedy 500.
Fastbreak
Hi, they call me Brad.
Ran a Spec 3+ at 440hp in the '05 S281 SC and it was too much. Loads of pedal pressure, and as someone else mentioned- the hotter it gets, the worse it gets.
BruceH
BBB Big Bore Boss 322
Ive ran rst clutches with power levels from 337 to 599rwhp. It's not too much clutch. The AM person didn't know what they were giving advice on.
jodadejss06gt
TEAM DELETE SHIT
Severn MD
I've dragged my RST that i got from Jeremy@S&H at my power for about 8 or so months. I've pulled a bunch of 1.5, 1.6, & 1.7's with it at the track. I drive it a few times a week. Great pedal, very close to stock. Pressure is good. My only grip is that it has shatter noise that is supposedly in all twin disc setups. It smells while at the track but has never slipped.
sharkbaits
We've had great success with both the RXT and RST.
If your interested shoot me a PM and I'll hook you up with one for a great price.
Department Of Boost
Alpha Geek
I went from running Spec Stage III+'s at 450 and 650hp. I thought it worked fine. A bit snatchy and a pretty heavy pedal but oh well.
Then I put a RST in...........forgetaboutit! HUGE improvement.:clap:
jodadejss06gt
TEAM DELETE SHIT
Severn MD
Only thing I didn't like about the RXT is that there didn't seem to be much skip in it. It seemed either fully engaged or disengaged. Didn't get much time in that friends car though.
suprchrgd
Noblesville, In
definitely had to re-learn how to drive the car with this clutch. the 4.10's helped for sure. its really grabby and i would buy another one...
908ssp
Michigan
You really can't have too much clutch. You can have too stiff a pedal. This might be a semantic argument I won't disagree with that but understanding is important.
Hatchman
Stangless
Chesapeake, VA
Yes you have a point but I think it goes beyond a stiff pedal. I think cost and drive ability is very important. Paying over a grand for a clutch for a stock car is just stupid, and that is too much clutch when a clutch half that price should "never" (unless abused or very old) slip and be much more drive able.
I think the general understanding is
too much clutch = you paid to much for it at triple the current hp/tq ratings of your car and/or the pedal is too stiff and/or the clutch is too grabby with no slippage when engaging.
But when the clutch pedal is all the way out, the clutch shouldn't slip, in which case you are right and at that point you can't have too much clutch, though you may have paid too much for it and after a few months your left leg is bigger than your right.
ZmanM3
The Evil One
Jackson, NJ
My spec 3+ with aluminum fly wheel has been working great for me, but I am sure that I am just use to it as well.
weather man
MN
I went with the steel flywheel...I'm surprised some think it has a heavy pedal. I only noticed slightly stiffer than stock.
