Flapjack
Lunatic engine swapper
I recently received the new GT500 shifter from MGW and decided to do a writeup. This shifter should work on any S197 with a TR6060, so long as you're using the stock GT500 shifter (need to reuse a few parts).
This guide is designed to complement MGW's instructions, not replace them. If in question, always fall back on their instructions, as they're likely more accurate than my methods.
To start out, the shifter is beautiful. It is easily the smoothest shifter I've ever had. The adjustability makes it even better. I currently have mine
set to 4, though I won't be able to really see if that's where I want it until the engine goes back in.
At any rate.... it's been a while since my last writeup, so here goes. As always, all pictures are clickable.
MGW GT500 Adjustable Short-Throw Shifter Install
______________________________________________________________________________________________________________________________________________________
Step 1
The first step for me was to put the car up on four jackstands, as high as possible. More than 1/2 the install is from the underside, so give yourself
plenty of room:
The first thing you may notice is the engine is out of the car. This is a luxury many of you won't have (hey... trying to stay positive). Later on in the
install, you'll see some pics from inside the engine bay. While you won't get the same view, it will help you visualize the clips that hold the
front of the shifter linkage to the tranny.
Step 2
The next step was to unpack the shifter components and hardware. Everything was incredibly well packaged and has everything you'll need (except for a bolt
you'll reuse from the stock GT500 shifter).
Step 3
Now we move onto removing the stock shifter from inside the car. Before you do so, make sure the shifter is in neutral. If you have any tires on the
ground, also ensure the e-brake is on. Even if you're on jacks, having the e-brake all the way up helps in removing the console (steps coming up).
Next, remove the leather boot and the shift knob from the car. You may run into a situation where you can't remove the knob because of factory loctite. I
didn't have any such issue, but there are helpful steps in the MGW instructions in case you have this problem.
Step 4
The next thing you'll need to do is begin removing the center console, both upper and lower.
Start with the two Phillips head screws under the lid of the rear console cubby. Once those are out, you can pull up on the upper console to remove it.
Some tugging is required, as the front is held down by fairly firm clips.
Throw it in the back seat :grinz::
Step 5
Next comes the lower console. There's a little more to this... but not much.
(Don't mind my giant wire mess. It's for all the wiring I did for the headrest monitors, rear IR transmitters, video amplifier, etc...)
First step, remove the plastic pillars on each side of the radio/heater control area. A good pull from behind should get them to pop out.
Next, clean out that center console and pull up the felt mat to reveal two nuts in the bottom. You'll need a long extension and a deep well 10mm socket to
get to these.
After the rear nuts have been removed, look towards the front. You'll see two 9/32" trim screws. A multi-bit screwdriver works great on these (the holes
where the screws are have been circled in red).
With all four bolts/nuts removed, pull up on the lower console starting at the back and work your way up. It should come up with just a little upward
force. When you're done, it should look like this:
Step 6
The next thing to remove will be the shifter handle itself. There are two 13mm bolts holding it down. Expect some yellow Ford Loctite... but it should
come out with a little muscle.
Step 7
Moving onto the plate, you'll probably have different bolts than me, so grab the sockets you need and remove all four bolts surrounding the lower shifter
assembly.
Mine was kinda heat-glued to the top of the tranny tunnel, so I used a screwdriver to pop it up. Once it pops, simply lift it off to expose the stock
shifter assembly.
...continued
Step 1
plenty of room:
Step 2
Step 3
Step 4
Step 5
get to these.
Step 6
Step 7
assembly.
shifter assembly.
...continued
