GlassTop09
Glad you caught that in time! Didn't see this in your sig......were you running the OEM HB at the time?I believe this damage is due to using a MSD two step too launch. Probably less than 20 hard blast offs. Notice the key way in the reluctor is wallowed out. The damper was still tight. The broken tensioner dowel fell of in my hand when I was removing the cam drive components. It was a real bear getting the screw end of that dowel out. I have read this is why a billet gear on the crank and inside the oil pump is needed.
