remainvayne
- Joined
- Jun 26, 2010
- Posts
- 283
- Reaction score
- 0
Several of the bolts that you use to fasten the muffler hangers to the body of the car no longer tighten. I know that it's the actually body of the car that is stripped and not the bolts themselves.
I sued to switch exhausts quite often and also switch out the mufflers for emissions every now and then. The mufflers are not quite loose and look like $hit because they aren't even close to being even while looking at the rear bumper.
What are my options for fixing the body's bolt threads? Can anything relatively easy be done or am I going to have to use self-tapping screws and drill into the body away from the existing bolt holes? I have used other temporary means, but not even Loctite or the works will keep my bolts tight and in place.
Any thoughts?
Any thoughts?
