While cruising, usually at low RPM in 4th or 5th gear, my car will nose down a bit and my A/F will jump from 14.x to 18-21. This will usually only last a second or two, and a bit of throttle will make it go away. Obviously, this is telling me I have a vacuum leak and somehow unmetered air is getting in to the motor. Last night the motor died a few times after cruising when I took it our of gear and I let the motor idle while coming up to a stop.
I thought my issue was related to the UPR catch can I plumbed in a few months ago, that air might be getting into the motor through one of those hoses, but apparently it's not because I removed the hoses and returned to stock configuration. I also replaced the hose going from the passenger cam cover to the CAI I have, and used clamps to secure it. I checked all the other clamps around the TB, CAI, filter, and found non of them loose.
Am I overlooking something?
