- Joined
- May 29, 2007
- Posts
- 1,067
- Reaction score
- 1
DivisionX Fuel components and systems for the 05-10 Mustang GT's and 07-12 GT500's. SUPPORT 1400+rwhp!! PLUG-N-PLAY OEM Style Connectors (No soldering needed)
These are now IN STOCK with same day shipping.
S197 Fuel Hat - Fits all 2005-2010 GT's and all 07-12 GT500's
DivisonX S197 Fuel Hat Manifold - Fuel Delivery - 2011-2012 Shelby GT500
Features:
Supports over 1400rwhp (with DCSS 465lph pumps)
Accepts Walbro GSS342's, DCSS 400lph , DCSS 465lph , DivisionX 340 Stryker Pump and the Aeromotive 340 Stealth Pump
OEM 6 PIN Connector for a guaranteed leak free PLUG AND PLAY setup
Uses a stock Level Sender for OEM functionality
CNC Machined Billet Aluminum
Black Anodized for a protective finish
Bolt-In Installation
Removes the restrictive PPRV valve
GT500 fuel rails - Fits all 07-12 GT500's
Fuel Rail Features:
-CNC Machined High Grade Billet Aluminum
-Anodized For Long Lasting Protective Finish
-Machined In Mounting Tabs designed to prevent tab failure found with other manufacturers fuel rails
-(2) Built-in 1/8" NPT Ports for electric or mechanical fuel pressure gauges or for fuel supply when using a wet nitrous kit.
-Fits Stock Eaton Supercharger, TVS, Whipple 2.9L, 3.4L, 4.0L, KB 2.8L, 3.6L
-Includes Driver and Passenger Side Fuel Rail
-Billet Aluminum mounting plate for FRPS with Viton O-ring
-Stainless Steel Mounting Hardware Included
Black
DivisionX 2007-2012 GT500 High Flow Billet Aluminum Fuel Rails (Black) - DivisionX - Fuel Rails - Fuel Delivery - 2011-2012 Shelby GT500
Clear
DivisionX 2007-2012 GT500 High Flow Billet Aluminum Fuel Rails (Clear) - DivisionX - Fuel Rails - Fuel Delivery - 2011-2012 Shelby GT500
GT500 Fuel Systems
System Includes:
DivisionX S197 Dual Pump Return Style Fuel Hat w/PLUG-N-PLAY OEM Connector
DivisionX GT500 Fual Rails (Clear or Black)
Aeromotive 10 Micron Fuel Filter
Aeromotive Pro-Series 4 Port 1:1 Boost Reference EFI Fuel Pressure Regulator
(2) High Flow Fuel Pumps
Lethal Performance PLUG-N-PLAY Dual Relay Wiring Harness
CHM 0-100psi Fuel Pressure Regulator
XRP and Fragola Fuel Fittings
Fragola Push-Lite Fuel Hose
OEM Level Sender
Loom Clamps, Self Tapping Screws and Zip Ties
Vacuum Hose and T- Fitting for Boost Reference
Complete Installation Guide with Diagram
850rwhp Uses dual walbro GSS342's
DivisionX GT500 850rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 2011-2012 Shelby GT500
1000rwhp Uses dual DivisionX Stryker 340 pumps
DivisionX GT500 1000rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 2011-2012 Shelby GT500
1200rwhp Uses dual Walbro TI Automotive 400lph DCSS pumps
DivisionX GT500 1200rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 2011-2012 Shelby GT500
1400rwhp Uses dual Walbro TI Automotive 465lph DCSS pumps
DivisionX GT500 1400rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 2011-2012 Shelby GT500
2005-2010 Mustang GT 3V Fuel Systems
850rwhp Kit
DivisionX 2005-2010 3V Mustang GT 850rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 05-09 Mustang GT
1000rwhp Kit
DivisionX 2005-2010 3V Mustang GT 1000rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 05-09 Mustang GT
1200rwhp Kit
DivisionX 2005-2010 3V Mustang GT 1200rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 05-09 Mustang GT
1400rwhp Kit
DivisionX 2005-2010 3V Mustang GT 1400rwhp Return Style Fuel System - Fuel Systems - Fuel Delivery - 05-09 Mustang GT
Features:
Fuel Rail Features:
Black
Clear
GT500 Fuel Systems
System Includes:
OEM Level Sender
850rwhp Kit
1000rwhp Kit
1200rwhp Kit
1400rwhp Kit
