- Joined
- May 29, 2007
- Posts
- 1,067
- Reaction score
- 1
NEW: Lethal Performance 05-10 Mustang Adjustable Motor Mounts!
$149.95
http://www.lethalperformance.com/05-09-mus...-mounts-p-30158
Works on all 05-10 Mustang GT's and Shelby GT500's
-Adjustable (Stock Height or 1/2" Drop)
-Allows More Clearance for Aftermarket Superchargers
-Made in the USA
-Aircraft Grade Aluminum
-Easy to Install
-Complete with Hardware and Installation Instructions
The Lethal Performance motor mount was designed with one thing in mind. Adjust ability. The reason we chose that as a platform for our motor mounts is because we found that the standard size motor mount doesn't work for everyone. As an example the 07-10 GT500 customers that want to run a larger twin screw supercharger under the stock hood need more clearance than the stock height mounts offer. A mount with a 1/2" drop to it though is the answer to allowing the customer to fit that blower under the stock hood. So we decided to offer our mount with an additional CNC machined spacer to allow the customer to decide which size mount they prefer to run. Not only does the mount allow for the stock height but the additional upper portion and hardware we supply will allow that mount to be lowered by 1/2". These are a direct replacement for your stock mounts and bolt right in.
Made in the USA with high quality aircraft grade 7075 & 2040 aluminum and custom poured polyurethane.
$149.95
-Made in the USA
-Easy to Install
