Redrocket06
Well the good news, fired the new motor last Friday. I dont think she made one full turn before it came to life, no odd noices that I could make out. Let her warm up a bit and turned it off. On the first drive it looked like the rings seated somewhere from 0 miles to 15 miles. My headers and exhaust pipe was still covered in old oil from when my stocker let go......basically the thing stopped smoking around mile 15 lol. I hate my exhaust, I think I will put my stock mufflers back on tomorrow, the straight through ones are too loud and drone, and resonate, no fun to listen to. Plus it is harder to hear any strange noises. I got the go ahead to take it to 4500 today, put 4 good pulls on it and got the logs emailed out to the tuner, I was nervous as hell. 11.5AF is what my gauge read and I think I hit 5+ psi, it is hard to watch AF, rpm and boost all at once. After about 75 miles and before I took it to 4500 I did pull the valve covers just to double check that everything looks ok. Still a noisey valve train but not as bad as when it was stock without phaser lockouts, I think my phasers were on their way out. It is going to be some time before I loose the butt pucker and upside down nervous stomach every time I open it up. Last Friday was the first time this car has seen the road since Feb 2011, when the stocker decided to go to motor heaven.
Motor:
298 Eagle kit with Diamond pistons from Livernois 9.3:1CR
.020" over and redecked block
Milled heads for smoothness
Upgraded springs
Lapped valves
Lunati 58006 cams (Me really likey)
Phaser lockouts
60 lb injectors (thank you Modifymystang)
400 lph pump, hat and wire upgrade (thank you Jeremy)
OBX longtubes and off road H
TSS oil pump
Livernois crankscraper
Vortech V3 with 3.6 pulley (boosted 12 psi on stock motor, stock cams with LT's)
And Devilsown methanol injection
Motor:
Upgraded springs
Lapped valves
Phaser lockouts
TSS oil pump
