crownaviation
http://www.tudyno.com/
I would give you 10:1 odds... They will say not their fault
New doesn't necessarily = assembled properly. They are FRPP not OEM correct? It's a simple a quick thing to do that could identify the source without the need to pull the motor. If all looks good afterwards then you still got a borescope that comes in handy for tons of projects around the house!
If I understand correctly they were new blanks that were assembled by the shop. Not the cnc heads.
I would have to check my receipts but i think it was around $700 when i had all that done at ATS.
Were you happy with ATS's work?
It would be a good reason for cnc heads if you are looking for a reason, lol. Around $1650 or so from Tasca with all new components.
How could valve stem seals go bad on brand new heads?
Maybe because Livernois Motorsports assembled these heads for FRPP and they suck!
Glad you finally took a look at them.
That's not how the op described it. He said he bought the new blank heads that are sold by frpp and had JDM assemble them. I still don't understand the FRPP stage 1 description, this is the only time I've ever heard it anyway.
I must have missed...or forgotten the part about JDM doing assembly since this issue has dragged on for so long. But the info you have listed should narrow it down. Who installed the guides?
I do know Livernois was receiving brand new cores since I saw pallets of them in their shop. Its now common knowledge that they are doing the work for FRPP. Did they also install the guides and seats on these Stage 1's? The OPs problems are consistent with problems others have experienced coming from Livernois' shop so I'm gonna step out on a limb....I'd feel pretty confident saying Livernois did the install and probably did not install the guides properly.
This is some of what I used as references for the Stage 1 information (just to further add to any confusion):
http://www.musclemustangfastfords.c...d_racing_three_valve_intake_manifold_testing/
I did note the part number was the same as the FRPP Stage 2. Not sure if the product line changed at some point in time or not.
http://www.fordracingpartsdirect.co...0_Mustang_GT_Top_End_Package_p/m-fr4-s197.htm
This add claims the FRPP Stage 1 have also been CNC'd.
Did they forget the valve stem seals, lol
What's JDM's stand on this? I'm just guessing, but I'd assume they would most likely give you some song and dance about how it isn't their responsibility or it's been too long or some other reason why they won't help you with the repair costs. They were plenty happy to take your money though.
Your build is the primary reason why I'll never spend a dime with JDM ever.
I'm think full dissassembly is in order..........
