Took the car to Atco last night to get some more seat time after doing a MVB 4R70W transmission swap. These are footbrake launches as I would spin trying to use the transbrake. Ignore the 1/8 mile mph, they had a sensor come off and they could not get it to stay on.
Very nice ET! I remember when only RACECARS could run that. You have a good combo there. Honestly, when you get it to hook on transbrake launches, you'll be knocking on the door to the 9s.
Don't know how much power I make. It's a Saleen supercharger with 15lbs of boost. A 9.0:1 compression built shortblock with stock heads and Comp 127350 cams. I have a circle D converter (3400 stall) and 4.10 gears. Those runs were footbrake launches at 1500 rpms.
It's a Performance Automatic Super Comp trans. It has a manual valve body and transbrake. The converter is a triple disk 3400 stall speed built by Chris at Circle D.
