Tony Conti
I have a no crank no start issue with my 09 GT, I got these codes before this happened
P1075, P0600, P1000, P2105 and U0300
The car was running like shit and misfiring very badly so I pulled it in the garage and shut it off. Scanned it and got those codes. I went to the house cause it was late at night and I wanted to get some sleep and tackle it the next day. I went outside and tried to start it but it would not crank. When you put the key in the ignition and turn to start the fuel pump doesn't prime and the dash lights won't come on… absolutely nothing happens. The battery isn't dead. You can lock and unlock the car too and the lights will come on. When you open the doors the windows will roll down slightly like normal and roll back up when you close the door. One thing that is weird is that when you lock the car the horn beeps really fast twice… it's never done that before and I've had it for two years. There are no blown fuses but there are some that aren't getting power. I checked the fuse box under the hood and the one by the passenger side footwell and no blown fuses… I am curious if the double beep means something because like I said it's never done that so I don't know if that is some sign of an issue… also before this happened I changed the fuel filter. When I went to plug in the fuel pump relay to prime the system I didn't disconnect the battery and as I was putting it in there was a spark but no smoke. I started the car and it ran fine… drove it for two days and then this all happened. In those two days, I put over 100 miles on it… I need help badly. I just don't understand whats going on. It went from running to a no crank no start within 24 hours and I didn't even move it out of the garage...
