I don't see the cartridges listed. Unless they just aren't showing on my phone. All I see is little packs or a gallon bucket.Youll have to buy a tube and use a grease gun.
Sent from my iPhone using Tapatwat
I will give you my opinion - don't use anything that comes in a tube from the auto parts store. None of it is meant to grease suspension bushings. You need dedicated bushing grease from Energy Suspension or Prothane. It's extremely tacky and thick, and is made to grease bushings - not ball joints. If you choose to use the stuff in a tube, you'll have squeaks back in a matter of months. Do it right this time.
http://www.energysuspensionparts.com/Energy-Suspension-Formula-5-Prelube-Bushing-Lube.asp
Okay, but how do you get that stuff in the zerk fittings to fill them up? I can see rubbing this on the outside of the bushings, is that what you mean?
That's the point, man. You have to take them apart, clean them, and grease them properly. You'll never have to use zerk fittings again, because they won't need to be re-greased.
Dont pull the bushings apart. What a waste of time. Clean the faces and re grease. You dont even have to use the energy suspension stuff though it is good. Just use some good synthetic injected in the zerks. Couple pumps. And drive it. Itll be fine.
The recommendation to use a bushing specific style lubricant, is a very good one.
Mobil 1 synthetic has proven to work decently, as well as Super Lube (what we offer)
Here is my personal favorite:
http://www.amsoil.com/shop/by-produ...-and-equipment-grease-nlgi-2/?code=GPTR2CR-EA
^That stuff is amazing. It is the best lubricant I have used, ever, on Poly bushing suspension pieces.
Good luck.
^ Keep us updated!
It's some bada$$ stuff!
