TheKid
Ok heres the deal ... I have a brake noise coming from the rear mostly the passenger side but both create this sound ... only does at light braking ... increase the pedal pressure it goes away ... also, at slow speeds i.e. under 15 mph ... high pitched squeal ...
Searched around a lil bit but couldnt come up with a solution other than some high-heat lube ....
I have pulled the back pads off looks like there is 50-60% life left in them, sprayed the rotors and pads down heavily brake parts cleaner hopin it was just alot of dust build up between the pads and rotors ... worked for all of two miles noise returned ... Now i have no clue what it is
Also, the back brakes seem to create two times brake dust the fronts do particularly the passenger side rear ... as it seems to generate alot more build on the wheels
Any Ideas?
Any Ideas?
