Curious, what grade oil are you guys running for track days or track cars ? 3v 4.6
there's a good thread on CC.com on oil weights for modular engines
Sorry Steve..
Off topic @ ArizonaGT, could I ask you to place a side shot of your car, with the black wheels (in sig pic), in the Pictures and Video section? Are those the Roush? They also look like the Axis Elite? It looks nice!
Tungsten Grey FTMFW!!
Note: I edited this post to say Pictures/Vid Section and not Tires/Wheel Tech Section
10w40 seems a bit excessive Dave, its twice as thick as factory recommendation, is there any main reason behind that decision?
Oil thins out when it gets hot, and continues to thin out the hotter it gets. I've actually watched my oil temp gauge go up and my oil pressure gauge go down while at the track...
Extra protection, or at least that is why i run 10w40 (same as dave).
I'm just paranoid, because i blew my WRX engine by not running thick enough oil at the track.
EXACTLY! Hot idle oil pressure on my car usually sits around 60 or so PSI, but after 20 minutes out on track, that drops to around 18PSI (!!), at least it did with 5W-20. With the 10W-40, that pit-in pressure seems to be around 30PSI, which is a lot more comforting. As I mentioned, my car is a seasonal one, and never sees cold temps, so the "thin" spec on the oil is of little interest to me at all. The 40-weight, however, is. It's my firm belief that the 5W-20 spec oil is there for CAFE purposes, and for no other reason. Since I could care less about the .02mpg that I'm losing to oil-pump related parasitic loss, AND since I flog the car pretty hard, I want all the protection I can get. A little birdie (who was on the Ford engineering team for the 4.6L 3-V) mentioned the following:
"(Shaking head from side to side) You should always run the specified oil, particularly if you track the car. (Starts nodding head up and down) You should never run another weight, like, say, 10W-40..." 'Nuff said, at least as far as I'm concerned.
