P-51 Performance
So i just installed my new stoker engintwo weeks ago..when i turned it over a noticed a oil leak coming from the rear of the oil pan.. drop every couple of seconds.at first i forgot to add a dab of rtv on the back corners of the oil pan where the rear crank seal and block meet...so i added it. (Bmr k memember ftw) and it still leaks not as bad tho.....took it old off and spreaded it alittle more and added it on both top and bottom of the oil pan gasket and still the same thing, might of made it worse not by to much to. The only other thing is the rear crank seal. I looked at my old engines rear crank seal and it has no signs of any rtv ever being on there. Its also totally flat, doesnt have any grooves to where rtv should go. This is the same with the new engine, totally flat. All i did was get the rear crank seal and bolt it on. Could i of maybe not tightened it on enough or i need to add rtv even if its all flat? Or do i need to remove the rtv and try it again? Or am i totally missing something?
