ddd4114
After a few years of lapping and constantly seeing slightly elevated lead in my oil analysis reports, I decided to add an oil pressure transducer to my 2011 GT and start logging. I ran an event at Mid-Ohio this weekend, and I immediately found the cause. After every sustained hard braking zone, I found that oil pressure would plummet after a couple seconds, and it would stay low until I released the pedal.
Here is an example of what I experienced (Black = longitudinal acceleration, Red = oil pressure):
You can see that oil pressure normally stays around 65 psi, but in long braking zones, it drops into the 20's. The engine is entirely stock with the exception of a Boss oil heater/cooler. I started the weekend with the oil level at the top of the dipstick range, and after noticing the problem, I added ~200cc of oil each session until the pan was overfilled by about 1 qt. I didn't notice any change.
For those who have found this problem before, what do you recommend? Would an oil pan like this: http://www.americanmuscle.com/frpp-boss-r-oilpan-1114gt.html really prevent the pressure loss in long braking zones? I'm afraid that the baffling will only delay the inevitable (and not by enough). Would an Accusump be a better solution? A dry-sump system would be pretty awesome but is not going to happen.
Thanks.
Thanks.
