1FastS197
keep us updated
will do!
keep us updated
So where would be a good spot to tap into for thee wastegate ya think. IDK what vaccum line work for it.
Wastegate should have a dedicated vac line the bov is fine with the gauge.
Ask on3 what spring came in their wastegate what ever the spring is, thats the minumum boost the car will make
just cuz it says 8lb spring doesnt mean thats what you will see. on my civic i had a tial wg 7lb spring but i only made 6.1lbs. my friend had a tubular manifold with tial wg 4lb spring and he made almost 15lbs. its a matter of wg placement, vac, source, and manifold design.
i know. you could have taken them out if you want they dont sponsor me any more. plus i have some more sponsors to add
There are tons of factors effecting how much boost you will actually see, wastegate quality is of course one of the bigger factors. The spring is just a starting point obviously.
My buddy has an 7lb spring as is only making 4lbs do to an exhuast leak and a crappy wastegate lol
yea i had a friend blow a freshly built motor cuz he saved a few bucks on the wastegate. im all for tial or go home.
I haven't heard anyone having problems with the bov or wastegate in the kit which is good. Also if I'm going to have to tap the turbo how big of a fitting is needed? Same size that's one the wastegate I'm assuming, or does it need to be bigger. It's crazy how much time little stuff takes, I've been working on like 4 things for 2 weeks it seems like. Hopefully this weekend I'll be done and able to get on the dyno and road in a couple weeks.
