Heaten m90
- Joined
- Jun 3, 2017
- Posts
- 335
- Reaction score
- 8
So I finished up putting back together my roush 07 427R and took it to get dyno tuned. On C16 it only made 366RWHP I've spent just about all of my money on this build and I'm highly disappointed I was hoping for at least 440. Please see mod list below and let me know what you think. I was supposed to get an E85 tune but that didn't happen it cost me 914 dollars for the tune. He was using HP tuners because he couldn't unlock my coper head ECM with my SCT x4
-AFCO duel pass heat exchanger
-FRPP hot rod cams
-80 LBS injectors
-400 LPH pump wiring upgraded
-62MM FRPP TB
-steeda CAI
-2.49 pulley
-street fighter coils
-heavy-duty roush tensioner
-Gt500 coolant pump
-1 3/4 full length long tube headers(wrapped)
-off road H-pipe to roush mufflers
-solid motor mounts/ sub frame connectors/front&rear struts
- 4" aluminum drive shaft/ aluminum flywheel
- 4.10 gears
- RAM clutch/ hydraulic TOB
- A/C delete
-305 hoosier A7 slicks all the way around
-full weight reduction(gutted)
-160 thermostat
-I'm probably missing other shit
-FRPP hot rod cams
-80 LBS injectors
-62MM FRPP TB
-steeda CAI
-2.49 pulley
-Gt500 coolant pump
- 4.10 gears
- A/C delete
-160 thermostat
