The HPX
The HPX will support the following horsepower
3" housing 640 WHP
3.5" housing 870 WHP
80mm or stock 05GT airbox 700 WHP
85mm housing 800 WHP
95mm housing 1000 WHP
100mm housing 1100 WHP
Updated sensor curve has been engineered to maintain perfect idle resolution even when used on vehicles making under 300HP.
This sensor can be used in any housing from 2" to over 5". It can also be used for blow-thru or draw-through configurations.
Limited lifetime warranty.
This is the last mass airflow sensor you will ever buy.
*Requires 05+ Ford maf connector
*Requires computer tuning
*Can be used on any 0-5V maf system with computer tuning
*Transfer function generating software tool available for FREE download
http://www.pmas-maf.com/resources/PMASHPXtool.xls
The HPX-E (Extended Range, 30% more range than standard HPX)
Extended range HPX
Will never peg.
The HPX-E will support the following horsepower
3" housing 840 WHP
3.5" housing 1140 WHP
80mm or stock 05GT airbox 920 WHP
85mm housing 1050 WHP
95mm housing 1300 WHP
100mm housing 1450 WHP
3" housing 640 WHP
Extended range HPX
Will never peg.
3" housing 840 WHP
