post picture of Used Spec clutch if you got one
Royb
irving TX
I'm clutch shopping again and have been through two spec stage 2+ clutch disc. I think the spec pressure plate is made wrong since it doesn't make proper contact with disc on that side due to wear pattern. I need some evidence one way or the other.
lostsoul
2014 vett or 2015 stang..
Gay Area
If screamn03 was here now I would have him take it apart from my car to show you and put it back =-/.. mine has been going good.. but then again I cant seem to use it correctly any how. :thud:
thump_rrr
Montreal Qc,
I can't believe that you spent the money on a T56 but didn't upgrade to a 26 spline input shaft.:hammer:
bry9
Crown Point,IN
Mine wore just the same as yours.. It never slipped at all. I was over 700 rwhp. Stage 2+.......
Royb
irving TX
that would be dumb - :poke:That's my spec 2+ out of my five speed not my T-56 it has the 26 spline input shaft.
Royb
irving TX
ok, good to know - spec tech says that is normal - I think it's a poor design by not using 100% of the surface area - in effect it recuces the over size & holding power that you could have.
