Racingtheburg
- Joined
- Aug 30, 2008
- Posts
- 2,827
- Reaction score
- 1
I have a couple of power coated and hydro dipped items ready to ship. Limited quantities.
1 Set of 2005-2010 Mustang 4.6L valve covers powder coated ford wrinkle blue.
$155 shipped to US 48. No core charge.
1 2005-2010 Mustang 4.6L intake manifold with money stackz design.
$260 shipped to US 48. No core charge.
1 2005-2010 Mustang 4.6L intake manifold with carbon fiber design. WITH OPTIONAL CPC SILVER MANIFOLD COVER add $150.
1 2005-2010 Mustang 4.6L coolant tank with carbon fiber design.
$95 shipped to US 48. No core charge.
1 2005-2010 Mustang 4.6L coolant tank with money stackz design.
1 2005-2013 Mustang Strut Tower Covers, Sold in Pair,Carbon fiber hydro dipped.
Made of high impact ABS with OEM textured like finish as used on the radiator cover panel.
**NOTE:Requires modifications to fit 2007-2009 GT500 Mustangs with a Strut Tower Brace, Does not clear Tokico D-Specs Struts and some coil-over systems**
Our shock tower covers are designed to fit over the standard OEM bolts on your Mustang. Some 2007 and newer Mustangs have bolts that are a little longer than normal. In these cases one of the four bolts or the center bolt may have to be cut down slightly for proper fitment of shock tower cover. If this modification is not made in cases where it is required, the shock tower cover may rub on the hood liner or center bolt, causing cosmetic damage to both.
Proudly Manufactured in the USA by CPC
$80 shipped to US 48.
1 2005 - 2013 Battery & Master Cylinder Covers Kit Hydro Dipped Carbon Fiber.
These covers are the perfect accessory to hide the battery and master cylinder and clean the look of your engine bay.
These attach to the front of the cowl, each using the two of the “factory” plastic clips that fasten the cowl to the firewall. Made of the same durable, OEM grade heat resistant material.
Special Note:
*To fit GT500 models, some hand trimming is require to provide clearance around the throttle body, otherwise it fits perfectly.
$180 shipped to US 48.
1 2005-2009 Mustangs NO Gt500. Hydro Dipped carbon fiber.
Add a little extra detail to your engine bay with this set of Radiator Extension Panels. This kit cleans up an area that, by factory design, looks like something is missing. These covers attach using existing hardware above the headlights on either side of the “factory” radiator cover.
Special Note:
**For use on cars with a NXT Generation hood lift kit, as there is no clearance hole for the factory prop rod.
** Will Not Fit GT500 or Bullitt Mustang Models**
$120 shipped to US 48.
1 2005-2009 Mustangs NO Gt500. Hydro Dipped money stackz.
Special Note:
I can ship overseas as well please contact me for a quote via private message.
TO PAY FOR ITEMS PLEASE PRIVATE MESSAGE ME FOR PAYPAL ADDRESS. FIRST COME FIRST SERVE.
Special Note:
Special Note:
Special Note:
