I just wanted to show some of the parts that I am getting along with updating my parts list.
I ordered a couple of non Ford parts and have been getting them in slowly and just stockpiling them until recently.
BMR A-Arm support brace - AAS-001
In talking with Kelly about these he had mentioned that for guys who are going to be drag racing their cars, they wouldn't need this as you aren't exactly putting a lot of stress on the A-Arms. For people who are going to be using their cars for road course or autocross or street driving this would make sense as you are tying the two A-arms together making them stronger and stiffer. There would be less deflection on the A-arms for improved handling.
MPR Racing Engines Billet Lower Crankshaft sprocket
This is made out of billet steel and is FAR stronger than the cast piece that Ford offers. On high boost applications, the factory sprocket has been known to break on cars with superchargers or turbochargers and will destroy your engine. Once this breaks, there is nothing holding the timing chains onto the crankshaft and thus your primary chains will have the potential to skip a bunch of teeth along the sprocket and will throw the timing off.
MPR Racing Engines heavy duty secondary timing chains
The problems with going with aftermarket cams and springs is that you may get a larger lift along with increased duration camshaft that the engineers at Ford never designed the secondary chains for. With these aftermarket cams, most will replace the valve springs that have increased spring pressure and seat pressure which will put some added stress on the secondary chains. For the most part, I think you will be ok to run the factory units but with the added RPM's and extended higher RPM's that the engine would see on a road course, I thought this would have been a good idea. I know I would have kicked myself if the cams broke on me. They feature thicker pins holding the chain links together along with thicker plates.
RGR/JPC Stage 2 heads - 1295
RGR lightweight phaser deletes - ????
These are going to delete the internals of the VCT phasers which is going to end up saving a lot of rotating mass off of your cams and timing system. While not expressly heavy, you can certainly feel the difference when you hold a stock phaser along with one of these phasers in your hand, especially with the exhaust phasers. If you are locking out the phasers, you might as well go the extra step and get these as well. Anything to gain an edge against your competition right?
RGR custom grind camshafts - ????
Well, these I can't really say much about these as the cam grinds don't belong to me. I will say however that in researching cams for the coyote in N/A form, it seems that the lift, isn't the important part. The thing you want to focus on here is the duration, as this is what is going to be making the most power with these motors. If you think about it, you are only at your maximum lift for a fraction of a second but the longer you have your valves open, the more air and fuel you can get into the combustion chamber as well as the exhaust gases out of the chamber.
Just as a point, it is possible to make cams lope in these cars. These aren't RGR cams, but I just want to point that out but it is too badass not to share haha.
https://www.youtube.com/watch?v=Q45KS7boguk
JPC Revised OAP - FDVA00002T
With the over axle pipes you are obviously removing the factory resonators but you are also gaining some power. With these you are going to gain somewhere around 7-15HP and when playing the N/A game, every little bit helps.
JPC Underdrive alternator pulley - 02020
This is a lightweight pulley and I can tell you that when they say lightweight, they mean LIGHTWEIGHT!!! This thing feels like a feather to be honest. Anyway, this replaces the pulley on your alternator which will slow down the alternator and increase the longevity of the alternator. JPC says that they see about a 2-4HP increase with these and on a coyote stock car these would be some BIG numbers when you have to run the same equipment as everyone else. As previously stated on a N/A build, just like with the 3V every little bit counts. You are going to need a bigger belt that is 70 7/8" belt which should be NAPA 25-060703 according to JPC. I haven't had a chance to measure this so once I do, I will confirm.
JPC Black Clutch line upgrade - CLK-B
JPC -12AN PCV fittings - 02017
Recently, Darren (the car in the video above) had been posting asking about some blowby issues and one of the suggestions was to go with larger AN lines from the valvetrain to the catch can so you aren't choking the motor and getting rid of the blow by fast enough. with this in mind, I said fuck it. I might as well get these and prevent any future issues. If it works cool, if not, no biggie right? Not to mention, this is MUCH cheaper than going with the 3 vane vacuum pump setup that you would need for road race applications.
Amazon.com: Aeroquip FCU1206 #4 Startlite Racing Hose: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/21TyduWH7OL.@@AMEPARAM@@21TyduWH7OL
The startlite hoses are 45% lighter than similar stainless steel hoses and IIRC they were something like 30g per foot lighter than the AQP Stainless steel hoses that Aeroquip sells. In the spirit of MattD ... weight savings bitch
Phenix Industries -12AN Compression Swivel Hose End Straight - J1200-3
Phenix Industries -12AN 90 degree compression swivel hose - J1290-3
Injector Dynamics ID100 Injectors - ID1000
I know that these are way overkill for my setup but if I ever wanted to go bigger and badder with the car I will be setup injector wise, not to mention I have been talking about getting an actual fuel system for the car so this is once less thing I would have to get when I go down that route.
VMP plug and play 40amp voltage booster -VMPAMPPNP
This makes wiring the voltage booster stupid simple! Just plug everything in and you are all set and I am all about convience here! Comes with everything you see here and is stupid simple.
Ford Racing Cobra Jet Setup
Cobra Jet Cold Air Intake - M-9603-M50CJ
Super Cobra Jet Monoblade throttle body - M-9926-SCJ
Cobra Jet Intake Manifold - M-9424-M50CJ
Kooks Green Catted H-Pipe - 11413610
Since I have to comply with emissions for NYS I decided to go with the Kooks green cats H-Pipe system which will tie into the existing Kooks side pipes I have. As is, the Kooks side pipes make the car fucking loud as shit and sound amazing so I am really dying to hear how they sound with the long tubes. The important part here is that these are 49 state legal so I should be all good to go with emissions.
ARP Head studs - 256-4702
ARP Harmonic Balancer Bolt Kit - 156-2502
ARP Flywheel Bolt Kit - 156-2801
I think that is everything for now but I am almost positive that I am missing things on this list so once I can find them I will update
this.
