S197BOSS302
Here to Learn
Hi, just looking to introduce myself and what I'm building. Back in 2011 after buying a 2012 Boss302 I was fortunate enough to go to Miller Motorsports Park to participate in the high performance driving school for Boss owners and also stayed another day which was spent in an FR500s. I fell in love with road racing and have been working on realizing my personal dream of road racing ever since. I aquired a NASA CMC2 campaigned '06 GT which had been gutted and caged with fire supression and required safety mods but otherwise was stock besides an APR Wing, MM Camber Plates and front brake ducting.
I am in the process of making major modifications to the car and am currently stripping it right down and seam welding it and starting from there. It will end up being a NASA ST2 car after its transformation, basically getting built like an AIX car but that class does not exist under my sanctioning body which is the WCMA and FIA here in Western Canada where I'm located. I'm really enjoying doing this complete tear down as I'm learning about every facet of the car which I believe will pay dividends in the future as I will know it it inside out. Along the way I expect to require advice and help with technical aspects that I'm not familiar with and thats why I'm here. I'm pretty new to forums so hopefully I'll get this figured out, so far though it's nice to be here I'm managing okay.
For some idea of where I'm heading with this build these are some of the more major parts I already have purchased primarily through American Muscle and Vorshlag. I love seeing that vendors are so involved on this site.
JBA Long Tube Headers and full offroad 3" exhaust
3 core Alum. Rad
Ford Racing Cooling Fan
Ford Racing Front Hubs
Cable and hardware to add a second fire extinguisher pull cable
New Window Net
Right Side Net
New Scroth profii2 Hans Seatbelts
Hoosier P295/30ZR18 R6's
Custom 18"x10" Forgestar F14's
SS Brake lines
Whiteline adjustable rear lower control arms
Whiteline lower control arm relocation brackets
Whiteline reverse rear sway bar
Whiteline rear upper control arm
Whiteline Watts Link
Energy Suspension bushings
Brembo Front Calipers BOSS302 Spec and single piece rotors
GT500 Rear Calipers and Single piece rotors
Ducted brake backing plates
BMR Tubular K Member with 1/2" lower engine mounts
BMR Front Control Arms
BMR Rad Support and two interconnecting braces (basically everything BMR has for the front end)
BMR weld in Subframe Connectors
Steeda adjustable bumpsteer kit
Front and Rear Strut Tower Braces
Hood and Front Fender Vents from Foose
A pre fabbed aluminum supercharger coolant tank from Moroso made to fit where the battery was which I will use as an Oil seperator/catch tank
American Muscle generic "Blue" cold air intake
I'm forgetting stuff already, but you get the idea
3 core Alum. Rad
New Window Net
Right Side Net
SS Brake lines
