my07silvergt
HOLD ON TO YOUR PANTIES
Ok so if this is in the wrong section I'm sorry
I'm currently having a belt jump issue, I pulled the IW overdrive crank pulley off and cleaned it up and used the appropriate install tool to put it back on and now I'm only jumping 1-2 ribs instead of 4. The belt is jumping towards the front cover so I'm assuming one of my pullies is not on far enough (is this correct?)
Also, the belt is only jumping off the lower pullies, ie: ac, crank, and power steering pullies, I've already ordered an ac delete bracket and I picked up a ps pulley install/removal tool to adjust that one. Any ideas or suggestions that might help me out?
