jlg333
So what's the most hp/tq you've pushed or still pushing on your mustangs stock block? How long did the motor last before it finally gave out?
Pro tip: Just because you make X amount of power on the dyno doesn't mean it will survive the track.
So the answer is... don't get greedy.
When you go FI it's a crap shoot on the stock shortblock. Some guys have run 550 with no problem and some guys have blown it up at less then 450. The rods are the weak point but the tune is usually at fault. The stock setup just can't take any detonation, the extra force caused by detonation will destroy the stock rods. Also all it takes is one weak rod and there goes you engine, even with a perfect tune. If you can't afford to replace it, then I recommend not going FI. It's just basic facts, if you go FI it can blow and if you can't afford for it to blow the don't do it.
I have a built motor and I have replaced it twice. Once due to the piece of shit that MMR built for me, it was built so badly that I had to pull it out. The second time I had a Comp Cams POS phaser limiter allow the phaser to come apart and this allowed the pass side cam to jump time. Lots of bent valves and dinged pistons on the pass side, along with a nice fire. I am running a conservative pump gas street tune, not an on the ragged edge race tune. It's just a fact of life, when you start pushing bigger HP out of these little motors anything can happen.
Earl
