I am almost positive it's the code related to the rear 02 sensors, because this happened after installing an offroad x pipe.What codes are being thrown? Always start there when asking for help.
Thank you.Swarzkopf said:Yep, I had to use two per side. Only one caused it to fault. With two stacked I breezed through PA emissions.
I, on the other hand, only use 1 set on each side and have passed. I honestly think that the whole 'non-fouler' thing is only a small (if that) part of the equation while the tune equates for 99.99% of the success rate...
Each package at oreillys comes with two. I had stock tune no codes ever. The one has to be drilled out that the o2 sensor screws into. Hate to ask what Brenspeed charged for something for $3.49 (x2) at oreillys. Not to bash any shops but shipping kills the deal for sure
It was $20 for a pair with shipping, but they come pre drilled.They charge $20 if I recall...
I forgot to ask, does PA do a visual check to look for cats?Swarzkopf said:Yep, I had to use two per side. Only one caused it to fault. With two stacked I breezed through PA emissions.
