Tonight I noticed my rear brake lights were on. Tried every trick in the book. That switch assy on the brake pedal appears intact. (4 way emergency flashers work fine)
I ended up pulling fuse #3 ( brakes) on the SJB fuse box as a temp..'fix'.
Now of course I have no brake lights at all, just running lights.... if lights on.
I did notice some dampness on the carpet, way at the top, just a tiny bit.
Pulled one strand of a pine needle that was stuck in the hole by the dash on pass side window..for the drain. Been raining heavily here the last few days.
What's the fix for this ?? This is on my 2010 GT automatic.
