Kona6Stang10
- Joined
- Apr 19, 2010
- Posts
- 538
- Reaction score
- 0
I know there are some people on here who do gears and differentials themselves...so, I have some questions for you guys.
About how long should I plan for these mods to be installed correctly?
What tools will I need? (IE: any specialty tools, as I have shop tools etc)
As far as making sure Backlash is set right....could I just use a combination of shims to make the same sort of specs as stock?
I have a tuner so getting the new gear ratio plugged in won't be a problem.....
Break in:
What is the recomended break in for new gears and locking differentials?
I've heard it's around 500 miles with easy throttle and not remaining at a constant rpm so that the parts can get used to the heat cycles ?
Thanks in advance guys!
Break in:
