Fabman
Children Of The Corn
Looks like them.
If it wasn't for the 2" lowering, you might be able to use yellows with them. Probably wouldn't have much headroom left on adjustment for the track though.
Norm
The Konis arent stiff enough?
Looks like them.
Norm
Nothing to do with stiffness. The housings are built to work at stock ride heights. You'll bottom them out frequently with that much lowering
Take it from someone who learned the hard way. Trying to band aid a setup that is not designed to work that way is a waste of $$$. The guy that had the car before me went through numerous spring sets and bars, and by the time it was done he said he should've just waited and bought a set of GC or Vorshlags setup. If I had it to do all over again I would go with big ass sway bars to get as much spring rate as I could out of stock height springs. Yes its a band aid but it will help until you can get a set of coilovers and can run correct spring rates with little to no bars. I am no suspension expert, but I can tell you what doesn't work well. Koni's with very low springs. A stock mustang on better tires will hurt your feelings at the tack all day long. Been there done that.
And easy buttons are worth it in the end ^^ Or you spend months taking it in the other end trying to piece-mill a suspension.
I agree when it came to finding springs for the car before coilovers. Now its way easier. I am king of trying to make something work while saving $$. But when I bit the small bullet (GC's) the difference was HUGE. I cant imagine how good the high dollar stuff is. But I can honestly say that if I only ran on the street I would never spend the $$ for coilovers. But on the road course it was mandatory. Going through corners and the car leaning so hard that my side view mirrors were dragging the ground, I knew it was time. But seeing that $$ come out of the account does hurt your feelings quite a bit! Not gonna lie.Very familiar with that strategy...this is why I was hoping to pick up a matching set of something that works. Since I'm no longer racing for points or money I had this illusion that this would be a little easier than it is. Before coil over cars we raced big spring cars and could easily get springs rated whatever we wanted in 25# increments....this whole thing about having to search for spring rates coded "Sport" or "K" or "L" or "Joe blows favorite setup" is just a slap in the face of racers everywhere. HTH am I supposed to compare if they don't put a damn number on it and rate them all with the same yardstick?
Rant over. I am going to go look at the Vorshlag stuff now.
Thank you all for your input, and please feel free to add your comments at any time....
Marginal, I think, particularly the struts.The Konis arent stiff enough?
