S&H 62mm billet tb group buy
TheBlackPearl
Savannah, GA
Did some porting on mine today. Just knife-edged the throttle blades and put in some counter-sunk screws.
Sent from my iPhone using it as a signal mirror.
Barricade
Decepticon Extraordinaire
The Alamo
Could use a How To....I'm a tad confused on the conical part...?
Sent from my Nexus 7 using Tapatalk
TheBlackPearl
Savannah, GA
I'm working out the kinks now, I ran into some alignment issues after I installed the new hardware. The throttle won't close enough so the car idles between 1500-2500 rpm. Once I have it figured out I'll post about it. I just don't want to tell you and have you mess up a good throttle body.
TBP
jonnieguns
TBP
That'd be awesome, I appreciate it.
Bobby
turbo gt about to go fast
Put mine on today. The car Fired right up and
Drove great. Might be a littlemore peppier.
idle hangs a little when clutch is in
The car feels smoother on the acceleration. I didnt get on it because i didnt know if my tune was off or not.
No, uses stock electronics that swap right over, includes the tool to clock your spring.
Group buy is over guys, price is $379 shipped in the cont. us.
Currently out of stock and awaiting the next batch.
sportinawoody
Piedmont area , N.C.
bolted mine up finally after sitting on the bench for over a month. reset the memory and let it warm up , took it out and drove it and I noticed quite a difference going from a bbk twin 62 to this twin 62. throttle response is much much better. when I get my exhaust swapped , I will be doing some back to back dyno from a stock 55, the bbk 62 and this and will post up my findings. Also, my car is whippled at 16 lbs on a 302
Bobby
Good to hear. I know my car is lean now after going from the stock tb to this. Dan will have to change my tune but i will wait till i go back after we finish the intake manifold. Then i will be shooting for 1000+ on pump gas 93 octane.
