Ok guys I've had 20X8 and 20X10 bullits in the past. They were pretty heavy and road a little rougher on the street vs stock 17's, but they felt wayyy better in the turns.
Of course they rode a little rougher on the street... You've stretched a rubberband around an aluminum thimble and called it a tire... No sidewall (to speak of) means that the tire is contributing that much less to the net wheel rate (spring, plus tire compliance, plus bushing compliance). You could keep the same, cushy ride, by going with good dampers and softer springs, but...
I also bet that the stock 17's were shod with stock rubber, which (Sorry, Sam!) generally sucks for just about everything. The 20's probably had a "super/ultra/maximum performance summer tire" on it, and THAT is most likely why you're feeling all the grip in the corners. It's not from the wheel, it's from the tire.
I'm looking at a new set of wheels and tires and love having fun on the street and would like to take the car on more road trips.
All good, but something is going to have to take a lesser priority between grip (fun) and treadwear/ride comfort.
What is the weight for the black or any 20 inch saleen 7 spoke wheels? Are they THAT much heavier than stock 17's? Also are there any draw backs of cutting turns hard on these larger wheels? Such as steering components ect. ?
30+lbs for just the rim???? Seriously???? If you're not thrilled with the ride quality of the ultra-low profile tires that you have to run on the 20's, you may want to think about going to a more "standard" size of tire, with some decent amount of sidewall to it. 255/45 (f) and 285/40(r) in 18" will maintain the stock net height, but still be very comfortable to drive on. If you use good rubber, it'll also be grippy. I'm not a fan of staggered tire sizes on our chassis (understeer anyone?), but those are the stock sizes on the GT500, and they're comfortable for an all-arounder. Staying with a "square" tire setup, I would shoot for 275/40-18. Still enough sidewall that at normal inflation it will smooth out the pavement a little bit, but if you pump up the pressure, you'll get pretty good road feel, grip, and turn-in response.
DISCLAIMER: I am NOT a fan of "Dub" wheels on the S197, unless the car is completely slammed, to the point where it's just about undrivable.
