Any updates on this one? Curious of what you found. Like I said earlier, as long as the air pressure was around 15-18 psi in the DR--and they are the same ones you used the 2 weeks prior with no sway--I think its still something in the rear suspension.
I just replaced the uca and mount, axle bushing, lcas, had the axle housing checked out and welded, che brace, panhard brace, panhard rod, lca relocation brackets and an axle girdle cover. Sadly, its now winter here and the car is away until Spring.
