Feb 23, 2012 #1 S Sofakingfast forum member Joined Jun 29, 2010 Posts 143 Reaction score 0 We used a spec single disc clutch in an 08 GT500, got it back together and fluid started coming from the center... Slave over extended???
Feb 25, 2012 #2 JeremyH 3V Fuel Guru S197 Team Member Joined Jan 10, 2009 Posts 20,857 Reaction score 197 Location Virginia Beach Sounds like it. The pressure plate fingers are going to be further away from the slave on a single.
Feb 25, 2012 #3 S Sofakingfast forum member Joined Jun 29, 2010 Posts 143 Reaction score 0 Yeah .... Spec sells a single for the gt500 but they say it need to use their flywheel only.. I figured I could use a 03 cobra flywheel... Anyone try that?
Feb 27, 2012 #4 5 51ngh forum member Joined Feb 26, 2012 Posts 179 Reaction score 0 I believe the flywheel dia is different between the gt500 models.
Feb 27, 2012 #5 S Sofakingfast forum member Joined Jun 29, 2010 Posts 143 Reaction score 0 no its the same as the termi...thanks
