I went from 225 8" spring to a 350 7" spring, not thinking about the difference in droop. Anyways now the car sits a bit higher. I was thinking of going to a 6" spring, and adjusting the collar up half an inch to give me another half in drop. Or is that getting a bit too short for a spring. My other problem is the bump stop. It is just about bottomed out, I put a shorter one in from the 07-10 kit, which is also softer as it is hollow. I have been tempted to remove it all together as I dont think the car can bottom out with the stiffness of the spring. Maybe Id use just a shorter bumpstop yet. Would these shocks have an internal bump stop? Or could I damage them by running an even shorter bumpstop? Also I remember someone talking about tire clearance on these, I was planning on running 285/35/19, as I believe thats the closest in tire height to the stock 255/40/19, just wondering when clearance becomes an issue. I have the vorshlag plates so I can put the camber to full positive at the spindle and adjust up top.
